nSedp
Jan 16, 2021Aspirant
Extending XR700 with MR60 & MS60
Hi, Can I extend my XR700 router with MR60 and MS60 both as extensions?
Jan 16, 2021Guru - Experienced User
No. the XR700 isn't a mesh router.
You can use the MR60 system as an access point system but devices aren't going to seamless roam from the XR700 to the mr60 system.
You could add a mesh extender to the xr700. I'd recommend the triband extenders (ex7500,ex7700,ex8000 or the RBS40V as it has extender mode)
- nSedpJan 16, 2021Aspirant
Hi,Thanks for the swift reply. I already bought the MR60 and MS60, but I cannot get it properly configured as two satellites. What are the proper steps? Or is it noy possible at all?`
