EQJunky
Oct 07, 2019Guide
Extreme gaming lag on raids.
I play an mmorpg called Everquest with 53 other people weekly. While burning a target on raids the lag is extremely bad, so bad I can’t click my buttons. Many other people in the raids have complained...
Oct 07, 2019Guru - Experienced User
Is the XR router connected to the S8000 switch and your game device behind he switch?
What happens if you just connect the XR only with your gamimg device with out the switch in the mix?
IF others are seeing same thing in the game, possible this is a Mfr of the game and game service issue.
What happens if you disable QOS and Anti Buffer features on the XR router, save settings and reboot the router and modem?
What Fw version is loaded on the XR router?
Might narrow this down even farther and connect up your gaming device directly to the modem and test the game out.
