EQJunky
Oct 07, 2019Guide
Extreme gaming lag on raids.
I play an mmorpg called Everquest with 53 other people weekly. While burning a target on raids the lag is extremely bad, so bad I can’t click my buttons. Many other people in the raids have complained...
Oct 08, 2019Guru - Experienced User
All this gaming with your friends at your home and all connected to the same router or at different locations?
And if you connect your PC directly to the ISP modem and game there, no lag?
EQJunky
Oct 08, 2019Guide
We are all connected at our individual homes located in different states etc. We aren't all at my house.
I just removed the switch from the setup and connected the PC directly into the router. When I connect the PC straight to the modem I dont get internet access for some reason.
The problem is we only raid a few nights a week and the lag only happens at certain points on certain events when we are all burning and stacked on top of one another so its hard to test when I make changes outside of raiding hours.
- FURRYe38Oct 08, 2019Guru - Experienced User
You'll need to power off the modem for 30 seconds then back on. Make sure your PCs netowrking configuration is set for auto obtain IP addressing. The PC will get a public IP address probably about a minute or two after the modem is online. This would help narrow this down to weather this maybe a game issue or router issue.
If others in your game group notice this as well from there locations, I would presume this is not a router issue, rather a game service issue.You might contact the game Mfr and ask them about any information regarding this and see if they have any kind of information about router configurations if needed.
There are many factor in seen LAG, Can gome from services, other gamers, ISP services and speeds used. Users using wireless connections for gaming rather the wired. And router configurations as well.
- Netduma-FraserOct 08, 2019NetDuma PartnerDifference between ping on Geo-Filter and server is that the server is including things like processing delay which all games have but not all decide to show. To me it sounds like an actual server issue that it's not able to handle the multiple actions in one area. Your ping and hardware is fine so I don't think that is the cause.
- EQJunkyOct 21, 2019Guide
It seems like my best dslreports bufferbloat readings and my lowest game lag and ping occurs when I have QOS and Antibufferbloat completely turned off on the XR500 and my S8000 switch set to 256out and 16in. I just don't get why I paid $350 for a router when I get my best readings with all of its functions turned off and the $80 switches functions turned on. Seems like I wasted $350 on a Netgear router when I should have kept my old Comcast router and just ran the S8000 $80 switch.
- CSPHX101Oct 22, 2019Aspirant
I normally shut the modem down for 30 second when I switch the device connected to the modem.
As for speed or lag when others connect to your server at home they are using mostly your upload speed which is 40Mbps since your connection is 1024 Mbps Down and 40 Mbps Up.
In my experience with this router even if you have a Gig Speed connection this router will only go upto !/2 a Gigabit per second max.
