EQJunky
Oct 08, 2019Guide
Extreme gaming lag on raids.
I play an mmorpg called Everquest with 53 other people weekly. While burning a target on raids the lag is extremely bad, so bad I can’t click my buttons. Many other people in the raids have complained...
CSPHX101
Oct 22, 2019Aspirant
I normally shut the modem down for 30 second when I switch the device connected to the modem.
As for speed or lag when others connect to your server at home they are using mostly your upload speed which is 40Mbps since your connection is 1024 Mbps Down and 40 Mbps Up.
In my experience with this router even if you have a Gig Speed connection this router will only go upto !/2 a Gigabit per second max.
EQJunky
Oct 23, 2019Guide
So even though my speed results at Speedtest.net is 950 should I only input 500 download speed into the bufferbloat QOS input of the router?
- EQJunkyOct 23, 2019GuideIt’s usually just me playing at my house so nobody else is using up the 40 mbps upload.
- Netduma-FraserOct 23, 2019NetDuma PartnerNo I wouldn't suggest doing that, you may throttle your connection unnecessarily, unless you want to actively use QoS then a good way of doing that would be to put in lower speeds then lower the percentage so you can be more precise.
