EQJunky
Oct 07, 2019Guide
Extreme gaming lag on raids.
I play an mmorpg called Everquest with 53 other people weekly. While burning a target on raids the lag is extremely bad, so bad I can’t click my buttons. Many other people in the raids have complained...
EQJunky
Oct 23, 2019Guide
It’s usually just me playing at my house so nobody else is using up the 40 mbps upload.
Netduma-Fraser
Oct 23, 2019NetDuma Partner
No I wouldn't suggest doing that, you may throttle your connection unnecessarily, unless you want to actively use QoS then a good way of doing that would be to put in lower speeds then lower the percentage so you can be more precise.
