Thakaekae
Aug 13, 2019Tutor
extremely slow WAN speeds
So i bought this router to see if it would have with my routing to Destiny 2 servers . When i was running the setup it initially said i had 117d/13.4u speeds. then shortly after i had to update firm ...
Aug 13, 2019Guru - Experienced User
- ThakaekaeAug 13, 2019Tutor
FW - 1.0.3.34
arris surfboard sb6183
my isp is spectrum i have the 100dl/10up plan
- Netduma-FraserAug 13, 2019NetDuma PartnerIf you didn't change any settings after the setup wizard then you wouldn't have changed the bandwidth settings to put in the speeds you should get to allow you to get to higher speeds. You can always downgrade to the previous firmware after completing the setup wizard if you find it to be more stable for you.
- ThakaekaeAug 13, 2019TutorLike in the QoS area with the slide bars? It auto.atically did that when I ran thru the set up. Checking internet speeds and I got 117.3 do and 13.6 I think upload. And that was hardwired and then a couple mins later after I finished the initial setup I had no speeds . Unless I am missing something I thought that's what that was all about.
