my340i
Apr 12, 2022Apprentice
Extremely Slow XR500 Router
Hey All, I have an extremely slow Nighthawk XR500 (Tested on V2.3.2.130 and V2.3.2.134) that is of course out of warranty. I am paying for 900 mbps which I am getting when wired to my modem. Whe...
Netduma-Fraser
May 03, 2022NetDuma Partner
It will always have had DumaOS but 3.0 is relatively new so depends when you purchased so worth trying one of the older versions to see whether it affects it at all: https://www.netgear.com/support/product/XR500.aspx#download
my340i
May 09, 2022Apprentice
Tried 2 sub 3.0 firmwares and there was no noticeable change.
- Netduma-FraserMay 09, 2022NetDuma PartnerI'd suggest reupgrading the firmware using the TFTP method, this bypasses the boot process and any issues there then once done do a factory reset for the freshest install possible: https://kb.netgear.com/000059634/How-do-I-upload-firmware-to-my-NETGEAR-router-using-TFTP-from-the-Microsoft-Windows-Command-Prompt?article=000059634 then see if the speeds increase
- my340iMay 10, 2022Apprentice
On it, soon as works over today I'll give it a shot!
Also ordered a RK1 router through my work since I get them at cost so I will have a permeant router to test with too.
- my340iMay 12, 2022Apprentice
Process was straight forward and worked well. I used the test directly on the router as well so no options have been touched yet.
Also ran some speed tests using speedtest, fast, and integrated speed test when you google speed test. (448, 380, 396)
- Netduma-FraserMay 12, 2022NetDuma PartnerOkay that's not too bad considering what it has set the speeds at, make sure to set the speeds you pay for then disable QoS fully and see what you get.
- my340iMay 16, 2022Apprentice
Done and done
Its definitely going to be bad though considering I'm 2ft from the router and 2ft away testing on Wifi.
Testing wired right by the router, same 3 websites - 376, 385, 397
Testing just downstairs through one floor on 5ghz (I would say a total of 50ft) 285, 291, 311
Pretty close to giving up on this, really frustrating $250+ routers cant last 2 years and come with 1 year warranties.
- Netduma-FraserMay 17, 2022NetDuma PartnerI think it may be best at this point to contact Netgear directly and see if they can arrange a replacement for you: http://support.netgear.com/
- my340iMay 17, 2022Apprentice
I wish, if you arent in warranty you cant even talk to them.
" I cannot find an answer to my problem, I would like to contact NETGEAR support. Based on your serial number and purchase date, NETGEAR can offer you the following support options:
SEARCH KNOWLEDGEBASE
VISIT COMMUNITY"
- Netduma-FraserMay 17, 2022NetDuma PartnerAh that's unfortunate. Okay as a test put your PC in the DMZ on the XR (remove once you've done the test), re-enable QoS and make a Traffic Prio rule for the PC, 1-65535 source & destination, TCP/UDP then see what speeds you get
- my340iMay 18, 2022Apprentice
Can do, would you also enable ipv6 or leave it disabled as it is.
- Netduma-LiamMay 18, 2022NetDuma Partner
Please leave it disabled for now thanks
