my340i
Apr 12, 2022Apprentice
Extremely Slow XR500 Router
Hey All, I have an extremely slow Nighthawk XR500 (Tested on V2.3.2.130 and V2.3.2.134) that is of course out of warranty. I am paying for 900 mbps which I am getting when wired to my modem. Whe...
Netduma-Fraser
May 17, 2022NetDuma Partner
Ah that's unfortunate. Okay as a test put your PC in the DMZ on the XR (remove once you've done the test), re-enable QoS and make a Traffic Prio rule for the PC, 1-65535 source & destination, TCP/UDP then see what speeds you get
my340i
May 18, 2022Apprentice
Can do, would you also enable ipv6 or leave it disabled as it is.
- Netduma-LiamMay 18, 2022NetDuma Partner
Please leave it disabled for now thanks
