rsherga
Aug 08, 2026Aspirant
Factory reset gained a navigable DumaOS
Same issue. FW 1.0.2.86. Factory reset gained a navigable DumaOS, but the restoration of backup config put me right back in the same boat again of "DumaOS is not running!" I unpacked the cfg file...
Aug 08, 2026Guru - Experienced User
The best and most likely solution is to do a factory reset which is generally advised after updating to a new firmware version. Then set up from scratch. Do NOT use the older backup config file. Once setup, generate a new backup configuration to file. You maybe introducing the problem using your older back up config file.
- rshergaAug 08, 2026Aspirant
Yeah that clearly is the factor at this point. Just sucks because what's the point of the backup if you can't use it across minor firmware updates?
(ヘ・_・)ヘ┳━┳ >>>>>> (╯‵□′)╯︵┻━┻
I'll update on completion.
