rsherga
Aug 08, 2026Aspirant
Factory reset gained a navigable DumaOS
Same issue. FW 1.0.2.86. Factory reset gained a navigable DumaOS, but the restoration of backup config put me right back in the same boat again of "DumaOS is not running!" I unpacked the cfg file...
- Aug 08, 2026
The best and most likely solution is to do a factory reset which is generally advised after updating to a new firmware version. Then set up from scratch. Do NOT use the older backup config file. Once setup, generate a new backup configuration to file. You maybe introducing the problem using your older back up config file.
Aug 08, 2026Guru - Experienced User
rsherga
Yeah that clearly is the factor at this point. Just sucks because what's the point of the backup if you can't use it across minor firmware updates?
(ヘ・_・)ヘ┳━┳ >>>>>> (╯‵□′)╯︵┻━┻
I'll update on completion.
- FURRYe38Aug 08, 2026Guru - Experienced User
Newer FW version may introduce some new features or incompatibilities with older versions of backup config files. So FR and setup from scratch then generating a new backup file will be needed.
Not sure what your symbols mean.
- rshergaAug 08, 2026Aspirant
Yeah all works as expected if i don't restore from backup. And it's just a character flipping a table out of frustration. See clipped image below.
So now generate a NEW backup configuration to file. I'd mark it for what FW version it came from so you know.
Please mark your thread as solved so others will know.
Enjoy. 📡
