joshwah1
Jul 22, 2019Initiate
FACTORY RESET NOW NO INTERNET
Hello, i factory reset my router now i cant connect to the internet it says its connected but the internet light is amber.. i cant seem to login to routerlogin.net either just says couldnt connect ...
- Jul 22, 2019
What are all the led's doing? blinking/solid/color etc
Why were you trying to factory reset it?
have you tried to reset it again? holding reset for 7-10 seconds. Sometimes it just takes a 2nd attempt.
you can also tried the 30/30/30 method. hold reset for 30 seconds while powered on, power it off for 30 while holding reset, power it back on while still holding reset for 30 seconds.
If none of these work, you can try resending firmware to it via tftp.
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
Jul 22, 2019Guru - Experienced User
joshwah1
I tried all the steps you asked and still nothing trying to update firmware it just says connection failed all the lights are on solid white except the internet light is orange when I click the Ethernet connection on Windows it says packets are sent and received but still nothing can't access the router login or anything either
- Netduma_AlexJul 23, 2019NetDuma Partner
If you disconnect the router from the modem, and just connect to it via ethernet, can you access the interface?
What IP address does your computer have when you do ipconfig in command line?
When you attempt to access the interface, have you tried routerlogin.net and also the router's ip address?
