naniasbr
Nov 02, 2019Follower
Fan not spinning
Hey there guys, I have been using my XR700 and I never noticed its fan spinning, is there way to check if it is working? Cheers
Nov 02, 2019Guru - Experienced User
It will only spin up when it's needed. Nothing you can do to check it.
- Netduma-FraserNov 02, 2019NetDuma PartnerThe fan will only turn on when there is heavy load, considering the hardware is high spec it's not surprising you haven't hit a level where it would turn on. I wouldn't worry about it but I suppose if you wanted to check then trying to saturate your network with lots of downloads etc and pinning lots of panels to the dashboard might do the trick. I've replied the same on your Netduma forum topic.
