naniasbr
Nov 02, 2019Follower
Fan not spinning
Hey there guys, I have been using my XR700 and I never noticed its fan spinning, is there way to check if it is working? Cheers
fibric
Nov 23, 2019Initiate
The router will very unlikely ever spin up the fans. In debug mode, you could play with the Fan settings, but don't do it. The same hardware is used in the older R9000 router, and even in summer streaming twitch on 6 devices never triggered the Fan's to blow.
Nov 25, 2019Guru - Experienced User
The fan will only engage when the operation is extreme and the temp limit is triggered.
