caseydang0407
Sep 19, 2019Guide
Fast LAN/Slow Wifi on XR450
Hello, I have a XR450 wifi router connecting to the Arris modem provided by Spectrum. I checked and compare the speed on various sites. When I test my computer by hooking up wired LAN, the speed is ...
- Sep 22, 2019
I finally found out the reason!
I didn't setup 2Ghz and 5Ghz radio frequency separately. Now when I connect to the 5Ghz one, I got over 200Mbps. With the 2Ghz, it is only 50Mbps at best. Didn't think that it is not automatically switch radio.
Thank you for all your helps.
Sep 20, 2019Guru - Experienced User
What speeds UP and Down do you pay for from your ISP?
Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM.
IPv6 and Set 20/40Mhz Coexistence to 40Mhz only.
What wifi devices are you speed testing with?
caseydang0407 wrote:Hello,
I have a XR450 wifi router connecting to the Arris modem provided by Spectrum. I checked and compare the speed on various sites. When I test my computer by hooking up wired LAN, the speed is around 90 Mbps. However, when I switch it to WiFi, it is only 50 Mbps. Everything setup with default settings. Do I need to do anything in the settings to twist the performance? I did updated the firmware, factory reset but those methods didn't work. Please give me advice.
Thank you
