caseydang0407
Sep 19, 2019Guide
Fast LAN/Slow Wifi on XR450
Hello, I have a XR450 wifi router connecting to the Arris modem provided by Spectrum. I checked and compare the speed on various sites. When I test my computer by hooking up wired LAN, the speed is ...
- Sep 22, 2019
I finally found out the reason!
I didn't setup 2Ghz and 5Ghz radio frequency separately. Now when I connect to the 5Ghz one, I got over 200Mbps. With the 2Ghz, it is only 50Mbps at best. Didn't think that it is not automatically switch radio.
Thank you for all your helps.
Netduma-Fraser
Sep 21, 2019NetDuma Partner
We don't have any specific ones that we recommend, as long as they can support the speeds from your ISP then it should be fine. Other users here may have some suggestions.
caseydang0407
Sep 22, 2019Guide
