asus009
Aug 14, 2020Aspirant
faulty xr700 netgear Terrible Customer Service
It is now 7DAYS later and still no contact! Netgear refused to return the product xr700 my speed test is about half as what they should be directly connected through ethernet I QoS is off then DumaO...
asus009
New ticket open still no reply
NETGEAR Support
2020-08-11 6:45:49
Dear xxxxxx, Thank you for choosing NETGEAR. My name is Priyanka, I am your support expert for today. I can understand your concern and I will surely help you with that. I would request you to re-flash the router firmware and perform soft reset to fix the issue Firmware download link: https://kb.netgear.com/000061373/XR700-Firmware-Version-1-0-1-20 Once update the route firmware, soft rest the router using below steps. Kindly take a back up of your wireless name and password. Below instructions for factor reset in soft mode. 1.Enter http://www.routerlogin.net. > A login window opens. 2. complete the route set up Please let us know the results so that we can determine the next action. ****Please be aware that your case will auto-close after 7 days of inactivity**** If you need any other further assistance, kindly visit our support web site www.support.netgear.com or community.netgear.com A notice will automatically be sent to your email address when I respond to your inquiry. Please DO NOT REPLY to that email. Instead, to add additional information to your case, click No to the question "Was your problem resolved with the information provided by the NETGEAR representative above?" If you click YES, your case will be closed and a separate email containing a survey link will be sent so you can share with us your customer support experience. Please rate the support and service I provided you. It was a pleasure assisting you. Thank you for choosing NETGEAR. Have a great day! Regards, Priyanka, NETGEAR Technical Support.
Online Comment
2020-08-11 11:38:06
Have tried all steps still the same speed issues.router is struggling to even achieve 400mb on my 1gbs connection
Netduma-Fraser
Aug 14, 2020NetDuma Partner
Sorry to hear you've had a bad experience with support. What I would recommend is actually upgrading to this firmware https://kb.netgear.com/000061714/XR700-Firmware-Version-1-0-1-24-Hot-Fix but upgrade by using this TFTP method: https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP this will bypass the boot process so if there are any issues there it should prevent them happening. Once you've done that would suggest doing a factory reset. That will perform the freshest install possible and hopefully resolve the issues.
- asus009Aug 14, 2020Aspirant
Thank you, I tried that but my speeds are still slow 370 down - 119 up done many test still same results
I just need netgear to exchange this router.☹
- Netduma-FraserAug 14, 2020NetDuma PartnerSo you tried using the TFTP method? How did you turn QoS off exactly? Did you do it in the Anti-Bufferbloat 3 line menu?
Hi,Yes Updated the router firmware using putty tftp
Qos Anti-Bufferbloat 3 line menu, Disable qos ticked
still the same very low speeds 370Mbps down, upload is great 122Mbps ping is around 3ms
Bt fttp 900/110 I contacted my Asus GT-5300 router getting 933Mbps down 122Mbps up
many thanks
