OlegP
Sep 16, 2018Apprentice
Feature Request: USB Printers
Please concider adding the ability to add a USB printer without the use of the ReadyShare software in your next firmware update.
Other brand routers allow you to simply add a printer to a compu...
Sep 17, 2018Guru - Experienced User
As a suggestion, one can get a print server device and connect up the USB printer to this print server which can be either wireless or ethernet conencted to the network for easy of access to a USB printer.
- OlegPSep 17, 2018ApprenticeSince I'm using all 4 Ethernet ports already that would mean that I'd have to purchase a switch and a print server, even though with a small tweak to the router's software I could use the USB ports on the router as intended.
- FURRYe38Sep 17, 2018Guru - Experienced User
Hopefully they will. May take longer than expected for that to happen. Suggestions would be much quicker...
Good Luck.
Do you know if Netgear actually check these forum posts themselves or am I just wasting my time?
I’ve posted twice now about 2 separate issues and haven’t even heard a peep from them.
