Auron111
Jan 23, 2019Aspirant
FFXIV connection issues over Ethernet
My setup is an Nighthawk XR500 + DM200 moden running ethernet from the router to my PC via a homeplug. a speed test shows the following :-
Ping- 13 ms
Download - 67.25 mbps
Upload - 15.76 ...
Auron111
Well the DM200 picked up PPPoE just fine, it connected to the interent and updated the firmeware as it should. Put it into modem mode only and thats where the problem is.
The XR500 just doesn't seam to want to see it even when connected, during the initial it searches for a internet connection but says it can't find it. Then surgests I power cycle the modem and make sure the ethernet cable is connected correctly, I did both yet the XR500 just doesn't want to see the DM200. So for now the DM200 will stay unpluged and tbh I might return it if it can't do its function properly.
The XR500 detected my ISP modem without an issue but the DM200..nope :(
Netduma-Fraser
Jan 24, 2019NetDuma Partner
Weird, if you go through the setup wizard anyway and input the details manually in Settings > Internet Setup does it work that way?
