undeadulus's avatar
undeadulus
Initiate
Nov 09, 2018
Fifa 19 connection problem
hello ,
I have a problem to find players in fifa 19 online  on PS4
every time I try to search for opponent  I got a message that say no opponents found ,
it happen on the second i press the search game.
i tried to disabled my GPS filtering and QOS and still have the same problem.
Is there any way to reslove it ?
  • it connected to Netgear DM200 and the version on the router is on v2.3.2.32-802-3-az-1009 (beta version)
    I got it fixed by lowering the MTU to ~1300 on PS4 network settings
    thanks for replay
  • FURRYe38's avatar
    What FW is currently loaded?
    Have you check the game services for information on there game?
    • undeadulus's avatar
      undeadulus
      Initiate
      thanks for replay
