ernieart's avatar
ernieart
FIFA on a XR500. how to better my ping?
So i mainly play fifa. in fifa in order to get the best gaming experience with less lag as well. you to have low ping. in fifa anything 30 ping or lower gets you into the full 5 bars of connection the game has. i am always hovering around 35-45 ping. so i stay on 4 bars connection instead of the 5 bars i which i have. the closest fifa server is in portland. i live in los angeles. i have set the perimeter to only get the that server. also never let anything else hog away from fifa when using it. have done other things as well but im not a wizard in connectivity.
this is my first post here. also my first ever gaming router. i know fifa isnt a shooter or other type of game. i got this router in hopes of dropping jus a few ping to get me the 5 bars in game. its very frustarting.
another thing is lots of timeS i get 5 bars for a second but than it goes away onto a 4 bar connection. This happens when i get into the online match up screen. not sure why that happens. wonder if that intels anything.
  • Distance is your biggest enemy here because you can't get a closer server in order to get a lower ping. It may not be possible to get a ping under 30 for that server but you will need to use QoS to try and get it as low as possible, what are your expected/paid for speeds and what are your QoS settings?
    • ernieart's avatar
      ernieart
      i get 300 down speed. wired as well. all i have done is use the perimeter bubble to reach out to the portland server. i also always turn off anything using speed while playing fifa. these are the main things i do. im not to savvy with the router yet. first tiem user.
    • ernieart's avatar
      ernieart
      Also did a trace. not sure if it helps.
      • Netduma-Fraser's avatar
        Netduma-Fraser
        NetDuma Partner
        What is your exact physical setup? Are ALL devices connected to the XR?
