ernieart
Sep 09, 2020Aspirant
FIFA on a XR500. how to better my ping?
So i mainly play fifa. in fifa in order to get the best gaming experience with less lag as well. you to have low ping. in fifa anything 30 ping or lower gets you into the full 5 bars of connection th...
Netduma-Fraser
Sep 16, 2020NetDuma Partner
What is your exact physical setup? Are ALL devices connected to the XR?
ernieart
Sep 17, 2020Aspirant
Hard wired is the PlayStation, Fire cube, main tv (Samsung). WiFi is 2 cellphones, Firestick and Mac. Though I disconnect everything from router. Jus PS4 is hooked up. The tv as well but it isn’t using any download speed when playing.
- Netduma-FraserSep 17, 2020NetDuma PartnerWhat is the XR500 connected to e.g. modem/router and are any other devices connected to that modem/router?
- ernieartSep 18, 2020AspirantRouter connected to modem ( Hard wired).Than have hard wired to router the PS4, tv, fire cube.
- Netduma-FraserSep 18, 2020NetDuma PartnerSo it is a pure modem with no other devices connected to it?
