ernieart
Sep 09, 2020Aspirant
FIFA on a XR500. how to better my ping?
So i mainly play fifa. in fifa in order to get the best gaming experience with less lag as well. you to have low ping. in fifa anything 30 ping or lower gets you into the full 5 bars of connection th...
Netduma-Fraser
Sep 17, 2020NetDuma Partner
What is the XR500 connected to e.g. modem/router and are any other devices connected to that modem/router?
ernieart
Sep 18, 2020Aspirant
Router connected to modem ( Hard wired).Than have hard wired to router the PS4, tv, fire cube.
- Netduma-FraserSep 18, 2020NetDuma PartnerSo it is a pure modem with no other devices connected to it?
- ernieartSep 18, 2020AspirantYes. Modem from my provider. One cable from modem to router. That’s it.
- Netduma-FraserSep 18, 2020NetDuma PartnerYour trace does show a high ping so not sure how far you'll be able to get it down. What ping do you get direct from the modem?
