Flareii
Dec 12, 2018Aspirant
Filezilla sFTP -- requesting specific port
I have read alot about port forwarding and triggering set up but I cannot get it to work.....YET.
I am using Filezilla too connect to a site using sFTP port 2691.
-Protocol is set to SFTP
Dec 12, 2018Guru - Experienced User
Is uPnP disable when you set up PF configurations?
Flareii
Dec 13, 2018Aspirant
i did connect the laptop directly to the modem and Filezilla worked fine. It was only when i reconnected the router and went through wifi that FIlezilla no longer worked. To specifcally answer your question, my modem is Motorola Sufrboard model SB6141.
Thanks so much for responding..hope you have some idea on how to fix
