Chook885
Mar 03, 2023Aspirant
Firmware 1.0.0.64 and nighthawk xr1000
I've just purchased a nighthawk xr1000 and had constant issues from the start with devices unable to connect to wifi connection. There was a time where lan connections weren't working either. I dow...
Netduma-Fraser
Mar 03, 2023NetDuma Partner
There isn't a specific issue like that isolated to that firmware version no. Could be a few things, some good advice above, in addition depending on your devices they may not like Smart Connect. Also switch the mode for 5GHz to 2400Mbps instead.
