Chook885
Mar 03, 2023Aspirant
Firmware 1.0.0.64 and nighthawk xr1000
I've just purchased a nighthawk xr1000 and had constant issues from the start with devices unable to connect to wifi connection. There was a time where lan connections weren't working either. I dow...
Mar 06, 2023Guru - Experienced User
Would be great if you could give feed back to the questions presented.
Do you have any apple and or android devices?
Chook885
Mar 06, 2023Aspirant
FURRYe38 - i have both android and apple devices which both couldn't connect to the wifi. i know you had a lot of questions but if you look at my summary i shared, it's pretty clear it's firmware issue.
- FURRYe38Mar 07, 2023Guru - Experienced User
I did. I also have Apple and Android devices and don't exhibit this issue with this version of FW loaded on my XR. Zero problems for these devices. Ran very well for me last year when I had it online last Nov:
I guess you'll need to wait for next FW update then to see if it fixes your issues.
Good Luck.
