NetriX
Sep 11, 2018Aspirant
Firmware 2.3.2.32 Breaks Internet Speed
Firmware 2.3.2.32 breaks my internet speed. I run a 1Gbps Up/Down connection. With the latest firmware my speed tops out at 56 Mbps.
QOS is disabled and proper speed is set in Anti-Bufferbloat ...
Sep 12, 2018Guru - Experienced User
Has a full factory reset been performed on the router after the FW update and set up from scratch and walk thru the setup wizard??
What is the Mfr and model# of the ISP modem?
You also can revert back to .v22 FW as well if you can't get the speeds right.
QOS is disabled and proper speed is set in Anti-Bufferbloat Options.
Reverting back to V2.3.2.22 has solved this issue.
