NetriX
Sep 11, 2018Aspirant
Firmware 2.3.2.32 Breaks Internet Speed
Firmware 2.3.2.32 breaks my internet speed. I run a 1Gbps Up/Down connection. With the latest firmware my speed tops out at 56 Mbps.
QOS is disabled and proper speed is set in Anti-Bufferbloat ...
Sep 12, 2018Guru - Experienced User
Has a full factory reset been performed on the router after the FW update and set up from scratch and walk thru the setup wizard??
What is the Mfr and model# of the ISP modem?
You also can revert back to .v22 FW as well if you can't get the speeds right.
QOS is disabled and proper speed is set in Anti-Bufferbloat Options.
Reverting back to V2.3.2.22 has solved this issue.
mncomputerguy
Sep 12, 2018Tutor
I can confirm I had issues with 2.3.2.32 as well, very slow internet speeds and enabling geo filtering would knock my xbox offline. Reverting to 2.3.2.22 fixed it for me as well. Is this other thread netgear/netduma acknowledged that it appears to be buggy firmware.
- Netduma_JackSep 13, 2018NetDuma Partner
It's worth noting that there are many users of this firmware who aren't experiencing any issues - we're trying to ascertain whether this is a bug with the firmware or something else. Thank you for letting us know what happened in your experience.
For anyone else experiencing major issues with 2.3.2.32, I'd recommend letting us know your issue first before downgrading - it's possible the issue could be fixed through simple configuration changes :)
