Jah1379
Feb 11, 2022Aspirant
Firmware flash
Hi, has anyone figured out how to flash Duma OS software onto the X10? The XR700 is the same router with the same specs
Netduma-Liam
Feb 14, 2022NetDuma Partner
Thanks for your interest in DumaOS.
Unfortunately, I'm afraid you won't be able to flash XR700 firmware to an X10. The firmware is locked to the model that it was built for, so it will only work if you're using an XR700.
