Roadrunner79
Oct 28, 2018Guide
Firmware to fix download speeds cut in half?
Can I get a firmware to try aside from the AZ 1009 beta???? I have tried everything to figure this out but my download speed is cut in half. Upload is not affected.
Netduma-Fraser
Oct 28, 2018NetDuma Partner
If we can figure out what's causing it we can fix it. Its either to with PPPoE, VLAN or IPv6. Those are the only scenarios we've seen the issue with.
- Roadrunner79Oct 31, 2018Guide
Isp was here on Sunday. Everything on there end is fine. PPOE and VLAN are disabled. Netgear asked me to change the MTU which did not help at all.
Isp was here on Sunday. Everything on there end is fine. PPOE and VLAN and IPV6 are disabled. Netgear asked me to change the MTU which did not help at all.
- Netduma-FraserOct 31, 2018NetDuma PartnerAs this is a new topic can you remind me of the specifics of your case please i.e. expected speeds, what you get, qos settings and what you've tried
All week long netgear XR500 has failed to detect bandwidth. Meanwhile the modem is fine.
