Roadrunner79
Oct 28, 2018Guide
Firmware to fix download speeds cut in half?
Can I get a firmware to try aside from the AZ 1009 beta???? I have tried everything to figure this out but my download speed is cut in half. Upload is not affected.
Roadrunner79
Oct 31, 2018Guide
I am crunkjuice1 over on netduma.
OlegP
Oct 31, 2018Apprentice
I feel like you’re having the exact issue as me.
I changed my modem to a totally different brand and that seemed to fix the halved download speed issue. Unfortunately, now I’m experiencing a different bug.
Are you within return policy at the retailer where you got your router? I highly recommend returning it. Maybe rebuy it 6 months later when the firmware is actually working right. If you decide to keep it then prepare to beta test it with the rest of us fools.
- Netduma-FraserNov 01, 2018NetDuma PartnerCrunk the speed test results is fixed in a later firmware but if you manually enter your speeds in Anti-Bufferbloat does it work okay?
