nighthoes
Apr 15, 2022Tutor
Firmware Update Failed (RX1000)
Model: NightHawk XR1000 First of all, I don't understand why such a prominent product is not even available in the product dropdown list provided for New Discussion. It's highly suspect...like en...
Apr 15, 2022Guru - Experienced User
1. this is the public support forum where members of the public help out. The netduma guys are on here and super active so you'll probably see a post from them. Less likely on a mod.
2. anytime there's an issues after a firmware upgrade, I usually recommend starting with a factory reset. maybe an old setting is causing an issue
3. I'd agree that most consumer gear is a bit overblown. Its hard to beat the business grade or home brew equipment.
