nighthoes
Apr 15, 2022Tutor
Firmware Update Failed (RX1000)
Model: NightHawk XR1000 First of all, I don't understand why such a prominent product is not even available in the product dropdown list provided for New Discussion. It's highly suspect...like en...
nighthoes
Apr 15, 2022Tutor
Thanks Netduma-Fraser for adding to the conversation.
I can confirm that the error cleared after clearing my browser cache, and I can login to the router again.
However, I now have this error reappearing on every app and management page:
I will try the suggestion, and I think that means I need to backup the configuration, since your suggestion seems to be to delete everything, which will clear my settings but keep the firmware upgrade?
Netduma-Fraser
Apr 15, 2022NetDuma Partner
I wouldn't suggest doing a backup and then restoring as you could then reintroduce issues. Better to factory reset, confirm no visual issues occurring, make your changes then make a backup so that if you need to reset again on this version you can restore.
It will wipe settings but keep the firmware version.
