JAS107
Feb 12, 2020Tutor
Firmware update
Hi there Ive had this Xr500 & has worked perfectly since late 2018. Ive a Wifi issue 2.4ghz as have apple homepods to which need to be on this (NOT 5ghz) on my Nice Gate openers The gate openers ...
- Feb 12, 2020I think I understand the issue, could you please set reserved/static LAN IPs for your devices in LAN Settings please. That should hopefully stop the disconnects. Then untick Disable IGMP Proxying in WAN Settings and that should help with Sky. If you're still running into issues disable QoS completely from the Anti-Bufferbloat 3 line option menu on the QoS page. What firmware are you on? You can find out by going to the System Information page.
Netduma-Fraser
Feb 12, 2020NetDuma Partner
- JAS107Feb 12, 2020TutorHi There
Thanks for information, I've carried out (except QOS anti buffer as yet) So thanks for your great assistance, most appreciated
Info: Firmware XR500 V2.3.2.56
