Vger2's avatar
Vger2
Firmware Version 1.0.1.50
Hello everyone. I recently updated my Netgear Nighthawk Xr700 wireless router with Firmware Version 1.0.1.50. Did a direct firmware download and updated via wireless router interface. Having issues after reboot with wireless connectivity. Did a reboot of router again and OK for a time, but wireless connectivity issues keep coming back.
Should I reflash firmware over again? Thanks
  • plemans's avatar
    Before doing that, I'd try a factory reset and reinstall. If you're having issues after a firmware update, its usually the first step we try.
  • As above, always recommended to do a factory reset after a firmware upgrade, let us know if that resolves the issue for you.
