brandoncbarker's avatar
Feb 05, 2018
Firmware Version 2.1.0.6 link broken?
Is there a new firmware out? I get an error when I go through support site.   https://www.netgear.com/support/product/XR500.aspx#Firmware%20Version%202.1.0.6   Thanks
  • brandoncbarker's avatar
    brandoncbarker
    Feb 10, 2018
    I appreciate it. It turned out to be my ISP. It was so intermittent it looked ok directly wired. I found out hours later not so much. Sorry for the inconvenience.
