brandoncbarker
Feb 05, 2018Tutor
Firmware Version 2.1.0.6 link broken?
Is there a new firmware out? I get an error when I go through support site. https://www.netgear.com/support/product/XR500.aspx#Firmware%20Version%202.1.0.6 Thanks
- Feb 10, 2018
I appreciate it. It turned out to be my ISP. It was so intermittent it looked ok directly wired. I found out hours later not so much. Sorry for the inconvenience.
brandoncbarker
Feb 08, 2018Tutor
Updated and factory reset and i am still losing packets/lagging. Any gaming is impossible. Tried downgrading to 2.1.0.4 and still same behavior. Hard wired to router still does the same thing. Hard wired directly to modem and all works so it’s definitely my router....
Netduma-Fraser
Feb 08, 2018NetDuma Partner
What console are you having issues with lag on? Is it just your gaming that is affected or do you experience buffering on YouTube for example on a PC?
How are you measuring your packet loss?
There are 3 likely causes for your lag issues. The first is that you need to be connected via ethernet to your game console, as great as the XR500 WiFi is I would always recommend wired. If you are on WiFi this could fix your issue immediately.
The 2nd is that you're experiencing local congestion & have not setup your QoS settings correctly. Set your Anti-Bufferbloat to 'Always' & give the download/upload sliders both 70%. For Bandwidth Allocation leave both download/upload equal. Ensure that share excess is enabled for both download & upload on Bandwidth Allocation.
The last cause is the Geo-Filter, that you're not utilising it to obtain a close server and thus getting a far away server which causes lag. If you are getting a local server then it could be the server itself causing issues. In which case I would recommend moving your home location/radius to avoid it. I would recommend using the Profiles on the Geo-Filter to setup the Map settings accordingly.
