brandoncbarker
Feb 05, 2018Tutor
Firmware Version 2.1.0.6 link broken?
Is there a new firmware out? I get an error when I go through support site. https://www.netgear.com/support/product/XR500.aspx#Firmware%20Version%202.1.0.6 Thanks
- Feb 10, 2018
I appreciate it. It turned out to be my ISP. It was so intermittent it looked ok directly wired. I found out hours later not so much. Sorry for the inconvenience.
Netduma-Fraser
Feb 08, 2018NetDuma Partner
I am based in the UK & so will be around for the next 4hrs to help on TeamViewer. If you're not available in that time I have PM'd you my email address, you can contact me directly that way and we can set up a time for TeamViewer. I really want to help resolve your situation.
brandoncbarker
Feb 10, 2018Tutor
