Darksound
Dec 18, 2023Aspirant
Firmware Versions Not Matching XR1000
I updated my firmware and the router shows different versions. In the top bar it lists 1.0.0.68_1.0.54.Under the system info tab is shows 1.0.0.64_1.0.49. I did perform a factory reset after the firmware was upgraded.
How do I get these to match?
Clear browser caches too?
Try a different browser?
- DarksoundAspirant
It worked from a different browser. Thanks!
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
