Netduma-Fraser
Dec 17, 2019NetDuma Partner
Fix for "DumaOS not loaded yet!" (XR500 users only)
Hi everyone,
We had a temporary problem tonight which caused XR500 users to see a white screen which says 'DumaOS not loaded yet'. This is now fixed. You just need to reboot your router and the pro...
JesseWright
Dec 17, 2019Initiate
This did not resolve the issue for me. I have tried upgrading from 32 -> 40 -> 56 and 32 -> 56 with reboots, but getting the same issue each time. Downgrading to 32 always works.
FYI, I'm doing my firmware upgrades/downgrades through the Ethernet and not over WiFi.
- Netduma-FraserDec 17, 2019NetDuma PartnerCould you go back to .56 please and then clear the cache/cookies in your web browser and see if it works then?
- Netduma_JackDec 17, 2019NetDuma Partner
Hi there - it should be working on the latest version again now. But if you upgrade to it and it's still not working, could you do a hard refresh please (Ctrl + F5 on your browser)? That will flush the cache which should then solve the problem
