Netduma-Fraser
Dec 17, 2019NetDuma Partner
Fix for "DumaOS not loaded yet!" (XR500 users only)
Hi everyone,
We had a temporary problem tonight which caused XR500 users to see a white screen which says 'DumaOS not loaded yet'. This is now fixed. You just need to reboot your router and the pro...
Netduma_Alex
Dec 18, 2019NetDuma Partner
The mistake was on our end. It was a one off problem and is unlikely to occur again.
Is the problem fixed for you now?
Tazzybakes
Dec 18, 2019Guide
Im up and running !! thanks Guys , just glad my router isnt busted , outages happen and comms is important. #learnings
