pablofm9
Jan 30, 2019Aspirant
Flashing R7800 firmware on XR500
Hello,
I have the XR500 router and have been experimenting with DumaOS. While I can appreciate the OS, I actually prefer the regular Netgear Firmware that I have used in the past. Is it possi...
Netduma-Fraser
Jan 30, 2019NetDuma Partner
There's no Netgear supported method for what you want to achieve. May I ask why you prefer that firmware compared to DumaOS?
- pablofm9Jan 31, 2019Aspirant
I don't like the interface (too much candy and not practical). Also it seems easier to manage devices and QoS settings for a non-gamer setup on the regular Netgear interface.
Just a thought, but not everyone will use this router for gaming. Some may simply want a better network for all users, including streaming...
Thanks!
- Netduma-FraserJan 31, 2019NetDuma PartnerWhat's not practical about it? What does the regular interface have regarding managing devices that you find better than DumaOS.
You're right, it's not just for gamers and the QoS is world class and will prevent lag for all devices on your network, ensuring they can all stream/download etc without local congestion- pablofm9Jan 31, 2019Aspirant
I don't find it practical. It should be easier to use and I dislike the fact that I don't have the ability to edit devices when viewing the QoS screen and instead have to switch back and forth.
Anyhow, it doesn't matter. I guess the answer to my question is no. I will check out DD-WRT which is supposed to have a working firmware.
As to someone who said that all the regular functionality is in DumaOS, it's not. I will give a simple example. In DumaOS it's not possible to set the router into Bridge Mode.
Thanks all.
