pablofm9
Jan 30, 2019Aspirant
Flashing R7800 firmware on XR500
Hello,
I have the XR500 router and have been experimenting with DumaOS. While I can appreciate the OS, I actually prefer the regular Netgear Firmware that I have used in the past. Is it possi...
pablofm9
Jan 31, 2019Aspirant
> May I ask why you prefer that firmware compared to DumaOS?
I don't like the interface (too much candy and not practical). Also it seems easier to manage devices and QoS settings for a non-gamer setup on the regular Netgear interface.
Just a thought, but not everyone will use this router for gaming. Some may simply want a better network for all users, including streaming...
Thanks!
Netduma-Fraser
Jan 31, 2019NetDuma Partner
What's not practical about it? What does the regular interface have regarding managing devices that you find better than DumaOS.
You're right, it's not just for gamers and the QoS is world class and will prevent lag for all devices on your network, ensuring they can all stream/download etc without local congestion
- pablofm9Jan 31, 2019Aspirant
I don't find it practical. It should be easier to use and I dislike the fact that I don't have the ability to edit devices when viewing the QoS screen and instead have to switch back and forth.
Anyhow, it doesn't matter. I guess the answer to my question is no. I will check out DD-WRT which is supposed to have a working firmware.
As to someone who said that all the regular functionality is in DumaOS, it's not. I will give a simple example. In DumaOS it's not possible to set the router into Bridge Mode.
Thanks all.
- Netduma-FraserJan 31, 2019NetDuma PartnerWhat about it isn't easy to use? Most router interfaces are quite confusing, we tried to make the most user friendly interface possible and we've received praise on that from lots of users. We've included ? icons in each panel to help explain the feature and how to use it. Is there something specific you find hard to use?
As in just editing their names on QoS?
Setting it to bridge mode would eliminate all the features that you would have bought the router for and it would be an expensive router just to put into bridge mode
