UrbanLegend
Nov 23, 2020Star
Fluctuating NAT type on Xbox One X with XR1000 router
Picked up the XR1000 (upgrade from XR500) and have multiple Xbox consoles (among other things) connecting to it one directly with ethernet and the others over wifi. Problem is that they all keep fluc...
Netduma-Fraser
Nov 23, 2020NetDuma Partner
In WAN Settings change NAT to Open and that should resolve it for you.
- UrbanLegendNov 23, 2020Star
Thanks, will give it a go and mark this as the solution once I have given the router a run.
Also, notice the XR1000 wasn't in the forums model options yet which is why I didn't tag it.
Gave it a go and while the wired one seems to stay on OPEN NAT, the ones connecting by wifi seem to be on Moderate NAT type.
- Netduma-FraserNov 24, 2020NetDuma PartnerShouldn't make a difference really. If you've got any port forwarding rules or a device in the DMZ take those out. Where are you reading the NAT status, in the console network settings or on a game?
