UrbanLegend
Nov 23, 2020Star
Fluctuating NAT type on Xbox One X with XR1000 router
Picked up the XR1000 (upgrade from XR500) and have multiple Xbox consoles (among other things) connecting to it one directly with ethernet and the others over wifi. Problem is that they all keep fluc...
UrbanLegend
Nov 23, 2020Star
Thanks, will give it a go and mark this as the solution once I have given the router a run.
Also, notice the XR1000 wasn't in the forums model options yet which is why I didn't tag it.
UrbanLegend
Nov 23, 2020Star
Gave it a go and while the wired one seems to stay on OPEN NAT, the ones connecting by wifi seem to be on Moderate NAT type.
- Netduma-FraserNov 24, 2020NetDuma PartnerShouldn't make a difference really. If you've got any port forwarding rules or a device in the DMZ take those out. Where are you reading the NAT status, in the console network settings or on a game?
- UrbanLegendNov 24, 2020Star
I have seen the setting in game but for the most part I'm using the Network settings on the Xbox dashboard.
Just turned on the wired console this morning and shows NAT type Moderate with the message UPnP not Successful.
I haven't set up any DMZ device or port forwarding rules.
Although now I need to do something else with the router as trying to go to the admin page is throwing the message
haserl CGI Error
Failed to readline from 'config get DumaOS_Theme_Version'
- Netduma-FraserNov 24, 2020NetDuma PartnerClear the browser cache/cookies and see if that lets you access. What is the XR plugged into exactly - what is the model of the modem/router?
