UrbanLegend
Nov 23, 2020Star
Fluctuating NAT type on Xbox One X with XR1000 router
Picked up the XR1000 (upgrade from XR500) and have multiple Xbox consoles (among other things) connecting to it one directly with ethernet and the others over wifi. Problem is that they all keep fluc...
UrbanLegend
Nov 24, 2020Star
Can confirm no port forwarding on the switch, even did factory reset and updated firmware to latest again.
Only things I changed were the password and disabled Bonjour discoverability since I don't use Mac and gave it a static IP instead of getting one from the router, everything else is default.
Netduma-Fraser
Nov 25, 2020NetDuma Partner
If you just put the Xbox in the DMZ does it appear open then at all?
