shaanshivananda
Jul 16, 2019Star
Follow Up: How to use the XR500 as a second router? How do I avoid double NAT?
Hi all, I recently posted about a Double NAT issue I was facing with the Netgear Nighthawk XR500 and the Xbox One X here 👉 https://community.netgear.com/t5/Nighthawk-Pro-Gaming-Routers/How-to-us...
- Jul 17, 2019The next step I would probably suggest is putting the console in the XR500 DMZ and see if that resolves it.
Netduma-Fraser
Jul 17, 2019NetDuma Partner
- shaanshivanandaJul 19, 2019Star
Hi Fraser,
Thank you so much for all the help! There was a confusion on my end which has been resolved by simply disabling "Instant On" on the Xbox One :)
Have a wonderful day!
Thanks!
- Netduma-FraserJul 23, 2019NetDuma PartnerGreat to hear that, thanks for the update! Don't hesitate to come back with any questions you may have.
- shaanshivanandaJul 24, 2019Star
Hey Netduma-Fraser!
Thank you again for the tremendous support I've received from this community. You guys are amazing and super patient. I think this community needs more visibility.
I purchased a Netgear product because I know Netgear makes the highest-quality networking products but if I had known about the amazing community built here, I would've been a die-hard Netgear fan ages ago. I have learned so much in the little time I've been active in this community and I really think that this community should be one of the reasons to pick up a Netgear product.
Look forward to being an active member of this community 👍
