shaanshivananda
Jul 16, 2019Star
Follow Up: How to use the XR500 as a second router? How do I avoid double NAT?
Hi all, I recently posted about a Double NAT issue I was facing with the Netgear Nighthawk XR500 and the Xbox One X here 👉 https://community.netgear.com/t5/Nighthawk-Pro-Gaming-Routers/How-to-us...
- Jul 17, 2019The next step I would probably suggest is putting the console in the XR500 DMZ and see if that resolves it.
shaanshivananda
Jul 19, 2019Star
Hi Fraser,
Thank you so much for all the help! There was a confusion on my end which has been resolved by simply disabling "Instant On" on the Xbox One :)
Have a wonderful day!
Thanks!
Netduma-Fraser
Jul 23, 2019NetDuma Partner
Great to hear that, thanks for the update! Don't hesitate to come back with any questions you may have.
- shaanshivanandaJul 24, 2019Star
Hey Netduma-Fraser!
Thank you again for the tremendous support I've received from this community. You guys are amazing and super patient. I think this community needs more visibility.
I purchased a Netgear product because I know Netgear makes the highest-quality networking products but if I had known about the amazing community built here, I would've been a die-hard Netgear fan ages ago. I have learned so much in the little time I've been active in this community and I really think that this community should be one of the reasons to pick up a Netgear product.
Look forward to being an active member of this community 👍
- Netduma-FraserJul 25, 2019NetDuma PartnerThanks a lot for the kind words, we're glad to have you in the community!
