ChaiYang
Jan 22, 2020Follower
Forgot Recovery Password
I forgot my recovery password to login into my Nighthawk RX500 router? What should I do to get into it?
Netduma_Alex
Jan 23, 2020NetDuma Partner
If you enter your password incorrectly 3 times, the router will enter the recovery process. You need to enter the router's serial and then answer the security questions you set.
If you can't remember the answer to the security questions, then you'll need to perform a factory reset using the button on the back. It's a small hole that you'll need a pen or a pin or something to press. Hold it for "up to thirty seconds"...
There's a guide here: https://kb.netgear.com/000053098/How-do-I-perform-a-factory-reset-on-my-Nighthawk-Pro-Gaming-router
Netduma_Alex
By the way, the serial is on the sticker on the bottom. Maybe take a picture of it.
