ChaiYang
Jan 22, 2020Follower
Forgot Recovery Password
I forgot my recovery password to login into my Nighthawk RX500 router? What should I do to get into it?
schumaku
Jan 23, 2020Guru - Experienced User
Netduma_Alex wrote:If you enter your password incorrectly 3 times, the router will enter the recovery process. You need to enter the router's serial and then answer the security questions you set.
If you can't remember the answer to the security questions, then you'll need to perform a factory reset using the button on the back.
Does the router continue to allow using the correct admin password, or can this be abused for some "fun" DoS?
Netduma-Fraser
Jan 23, 2020NetDuma Partner
What are you referring to schumaku?
