P44EFC
Jun 01, 2020Apprentice
full fibre 900 BT
Recently had FTTP installed with BT for the 900 dowload package. Factory reset the router before using as it had the old connection on and setting back up was easy enough and the wizard got me th...
- Jun 03, 2020
Thanks for the response ok i will give that ago when i am home cheers.
Netduma-Fraser
Jun 02, 2020NetDuma Partner
It can sometimes take a few days for the router to sync properly with the ISP, during this time speeds can be reduced. However, to check, go to Device Manager and look at the table view. Make sure the link speed is at 1000mbps for all ports. Then go to QoS and disable QoS in the Anti-Bufferbloat menu and see if you get full speeds then. If not then in Internet Setup set the router MAC address to the MAC address of your previous router and then apply and reboot and see if speeds return.
P44EFC
Jun 03, 2020Apprentice
